"Semantic DB authentication failure" alarm
  • "Semantic DB authentication failure" alarm
  • CraigEl
    CraigEl
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2022-02-02 03:01 PM
on ‎2022-02-02 03:01 PM
In EBO 2022 or higher the "Semantic Engineering View" button is grayed-out in EBO WorkStation and "Semantic DB authentication failure" is shown in Alarm View.
"Semantic Engineering View" button is grayed-out and "Semantic DB authentication failure"  alarm"Semantic Engineering View" button is grayed-out and "Semantic DB authentication failure" alarm
Semantic db authentication errorSemantic db authentication error
Building Operation Workstation
 EBO user that connects to the Sparql database has the wrong username and/or password.
Make sure that the user configured in EBO semantic settings matches the user created in the GraphDB web interface.
  1. In WorkStation, in the System Tree pane, select the EBO server.
  2. Click the Control Panel tab.
  3. Click Navigate to Sparql database, this will open the GraphDB web interface.Navigate to Sparql database.png
  4. Login with the admin user account.
  5. In the top right corner, make sure that correct repository is selected, default name is "nsp".
  6.  Go to Setup -> Users and Access.
  8. Set a password for the "nspService" account and make sure it has access rights to the "nsp" repository then click save.Graphdb edit user 2.png
  9. In EBO WorkStation control Panel, open Semantic Settings.
  10. Set the password for username "nspService" to match the password set in the GraphDB interface.Graphdb edit user 3.png
For more information, please refer to the GraphDB help: Secure GraphDB — GraphDB SE 9.10.0 documentation (ontotext.com)
  • MahmoudSayed22
37% helpful (7/19)
