"Programming contains links" pop up message seen when doing health check or updates
  • "Programming contains links" pop up message seen when doing health check or updates
  • RobertAndriolo
    RobertAndriolo
  • AdamSteele
    AdamSteele
Guinan AdamSteele Guinan
‎2019-05-14 09:27 PM
Seeing a pop up warning message when updating modules or making changes to an online Controller.
“It has been detected that your programming contains links between controllers, but the firmware on one or more of these controllers does not support this. Therefore the manual command you are trying to perform may not behave as intended. Are you sure you wish to continue?”
Figure1 - Pop up messageFigure1 - Pop up message
EcoStruxure Security Expert
  • Security Expert Client
  • SP-C
Configured Programmable Functions are trying to query the state of inputs on expander modules but this is failing due to one or all of the expander modules being offline.
Bring all the expander modules online and the error message will no longer be seen.
  • EcoStruxure Security Expert
Tags (2)
  • AdamSteele19
  • AdamSteele23
