"Priority not changeable" message when binding SNVTs
  • "Priority not changeable" message when binding SNVTs
  • RobertAndriolo
    RobertAndriolo
  • PeterEdvik
    PeterEdvik
  • sesa150555
    sesa150555
‎2018-09-06 11:04 AM
Last Updated: Picard RobertAndriolo Picard ‎2021-12-12 03:33 PM
"Priority not changeable" when binding SNVTs
  • Building Operation
  • LonWorks Bindings
In the XIF file, you can specify if the variable should be sent by default with priority. You can also specify if this should be changeable. If both devices are set to not changeable and they use a different flag in the priority setting, you get this message.
The 2 devices are not compatible. You can not make the binding.
Tags (2)
  • 11240
  • PeterEdvik21
