"No data records found" when using Entitlement ID on Flexnet Operations site
  • "No data records found" when using Entitlement ID on Flexnet Operations site
  • Cody_Failinger
    Cody_Failinger
  • Sacco
    Sacco
‎2018-09-07 12:51 AM
Last Updated: Administrator Cody_Failinger Administrator ‎2020-05-21 09:41 AM
Schneider Electric Flexnet Operations (https://schneider-electric.flexnetoperations.com)
Though you may be able to log into FlexNet with your Entitlement ID, many customers have been getting "No data records found" when trying to activate a license. Apparently, the Activation is case sensitive though the initial Login is not.
Use capital characters when logging in which should correct this problem.
  • 2740
