"Loading Properties" pop up displays but never finishes when an object is accessed in a Xenta controller.
  • "Loading Properties" pop up displays but never finishes when an object is accessed in a Xenta controller.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:31 AM
When extended trend object was opened in the Xenta 401 the "Loading properties" does not close down.  The controller appeared fine in all other respects.
Xenta 401
In this case two technicians coincidentally attempted to access the same object at the same moment.
Problem was resolved once the controller was downloaded.
  • 12899
0% helpful (0/1)
