"Invalid card number" error when Importing custom format personnel records.
  • "Invalid card number" error when Importing custom format personnel records.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:47 AM
When importing custom format card records, Continuum fails to create personnel objects for records where the card number has seven or more digits.
  • CSV Import
  • Personnel records
  • Custom Format
  • Continuum defaults to Infinity_37 When the card format is not specified in the import file.
  • While custom formats can accommodate larger card numbers, Infinity 37 cards only support card numbers up to 524287.
  1. Add a attribute column for cardtype.
  2. Under the card format column for each card, add Customwiegand.
  • 12094
