"Error code 401 - Unauthorized" in XBuilder
  • "Error code 401 - Unauthorized" in XBuilder
  • Trey_Boothe
    Trey_Boothe
  • CraigEl
    CraigEl
  • sesa177673
    sesa177673
‎2018-09-06 11:44 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-08 10:37 PM
When trying to download a 5/7/9xx in XBuilder you get "Error code 401 - Unauthorized".
Satchwell MicroNet, TAC INET, TAC Vista
  • Xenta Server
  • Xenta 511, 527, 555, 701, 711, 721, 731, 913
  • XBuilder
Password in XBuilder project does not match the password in the Xenta device.
  1. Select the 5/7/9xx in the Network panel
  2. The password is in the right hand panel of XBuilder under the TCP/IP Settings section.
  3. Change this to match the password in the 5/7/9xx.
If the password is not known then refer to Receive a temporary session password for a Xenta 5/7/9xx if the password has been lost.
Labels (3)
  • Satchwell MicroNet
  • TAC INET
  • 11308
