"Error 7 updating firmware--cannot start bootloader" when attempting to upgrade firmware in a MNB-1000
  • "Error 7 updating firmware--cannot start bootloader" when attempting to upgrade firmware in a MNB-1000
  • RandyDavis
    RandyDavis
  • Kim_Baze
    Kim_Baze
‎2018-09-06 02:52 PM
Last Updated: Guinan RandyDavis Guinan ‎2019-10-09 06:20 AM
When attempting to upgrade the firmware in an MNB-1000, this error appears:
"Error 7 updating firmware--cannot start bootloader".
It appears like the MNB-1000 is running for a short period and then resetting.
TAC IA Series
I/A Series MNB 1000
On occasion, activity on the MSTP trunk will cause this error.
  1. Access the MNB-1000 and disable the MSTP trunk.
  2. Attempt to upgrade the Plant controller again.
    Note: Use an IP connection to the MNB-1000 for the upgrade.
  3. Re-enable the MSTP trunk once the upgrade is complete.
  • TAC IA Series
  • 2878
