"Download Java" link shown when accessing TAC Vista Webstation from Internet Explorer
  • "Download Java" link shown when accessing TAC Vista Webstation from Internet Explorer
  • RobertAndriolo
    RobertAndriolo
  • Benji
    Benji
  • sesa150561
    sesa150561
‎2018-09-11 08:19 AM
When opening a TGML graphic in Webstation using Internet Explorer you get a link to download the correct Java version even though Java is installed on the PC used
  • Java
  • Vista Webstation
  • Internet Explorer
Webstation has a built-in check to see if Java is installed which does not work in Internet Explorer
Open this path "C:\inetpub\wwwroot\TACVistaWeb519" Version can be different depending what you have installed.
Edit the file "TgmlDynamicGraphicsPage.aspx" and remove the lines in picture starting with <script< strong=""> and ending with /script></script<>
NOTE: Make a backup of the file in case something happens.
and save the file.
Also remember to set the viewer mode to "Dynamic" in TAC Vista Web Settings. The down side of this, is that Webstation will not work on PC's not having Java installed.
  • 17946
