"An unknown error occurred while downloading" error reported at end of WorkPlace Tech LON controller download.
  • "An unknown error occurred while downloading" error reported at end of WorkPlace Tech LON controller download.
  • RandyDavis
    RandyDavis
  • sesa116868
    sesa116868
‎2018-09-10 11:32 PM
Last Updated: Guinan RandyDavis Guinan ‎2024-12-16 10:48 AM
At the completion of the download of a WorkPlace Tech application into an LON controller, the following error window is displayed:
TAC IA Series
  • WorkPlace Tech Tool release 5.x.x
  • I/A Series MNL Controller application file
A default nci constant is out of range for its variable type.
Verify that all nci values are valid for the SNVT type, re-compile and re-download the application.
The most frequent issue that causes this error is an invalid text string value for a nciLocation SNVT.
  • TAC IA Series
Tags (2)
  • 12483
  • RandyDavis24
