"An error occurred while installing the directory service" when reloading Continuum controllers
  • "An error occurred while installing the directory service" when reloading Continuum controllers
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 10:14 AM
Last Updated: Administrator DavidFisher Administrator ‎2019-08-26 08:39 AM
When reloading controllers, Continuum reports the following error: "An error occurred while installing the directory service."
Andover Continuum
  • Continuum
  • Alarm Points
A Continuum object is referencing a point in a controller that is offline or that requires a reload.
Either reload the controller that owns the referenced point, or restore communication with that controller.
  • 13808
