iLon600 use with EcoStruxure Building Operation (EBO)
  • iLon600 use with EcoStruxure Building Operation (EBO)
  • RandyDavis
    RandyDavis
  • Trey_Boothe
    Trey_Boothe
  • sesa150555
    sesa150555
‎2018-09-06 09:28 AM
Last Updated: Guinan RandyDavis Guinan ‎2025-01-23 11:48 AM
How do you use iLon600 in an EBO Project
  • EcoStruxure Enterprise Server
  • Echelon iLon600
When to use iLon600 in EBO
There are no support for iLon 600. EcoStruxure only supports Loytec network interfaces. See datasheets for exact models.
If you are engineering a new system you should get Loytec products.
The Loytec NIC has support for iLon600 so you should be able to add a NIC852 and one L-IP (to use as a config server) and use the iLon600 as router. This have not been tested but should work.
Only supported interfaces are listed in the datasheet.
Tags (2)
  • 16597
  • TreyBoothe24
