acctrace is not creating the .csv file or change the path to the file
  • acctrace is not creating the .csv file or change the path to the file
  • Alan_Wood
    Alan_Wood
‎2018-09-06 01:33 PM
Change the path of acctrace .csv file
  • Continuum
  • Windows XP
  • Windows Vista
  • Windows 7
  • Windows Server 2003
  • Windows Server 2008
There are permission restrictions to the Continuum folder or there is a need to change the path to the acctrace .csv output file.
If permissions are restricted to Continuum, you can change the path to this file. A good troubleshooting step is to send the file to c:\temp
When starting acctrace there is a field called "Filename for trace output:"
To change the path for the .csv file add the path in the field called "Filename for trace output:"
Ex. C:\Temp\ACCTrace_datetime.csv   (leave the actual datetime that the program creates and only add the path C:\Temp ahead of the filename)
* On a Windows7 PC, the User Account Control changes the default path where files are created by ACCTrace. If Continuum is installed on the C drive, look in the following path for the trace file that is created:
c:\users\username\appdata\local\virtualstore\program files\continuum
  • 5682
