Xenta server versions!
  • Xenta server versions!
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 12:13 PM
When importing a Xenta server to another it is important that they have the same version but is it also important that the hotfixes(if installed) is the same?
Xenta server up to version 5.1.7
In version 5.1.7 and prior versions hotfixes have not changed this part of the code so if the Xentas have the same version it should work.
It is enough if the version of the Xenta servers is the same
  • 8178
