XIF and NXE files for a SVEA Lon I/O Module DR-N-3D1M (0-10V) module
  • XIF and NXE files for a SVEA Lon I/O Module DR-N-3D1M (0-10V) module
‎2018-09-06 09:40 AM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:29 AM
Need to download the XIF and NXE files for a SVEA Lon I/O Module DR-N-3D1M (0-10V) module, but having difficulty locating these files on the Extranet.
Andover Continuum, EcoStruxure Building Expert, EcoStruxure Building Operation, Satchwell Sigma, TAC Vista
  • SVEA
  • XIF
  • NXE
The difficulty in locating these files, is due to them being identified by their article number, in this case DR-N 3DIM. This number was used when these were classified as the SVEA devices. The Schneider version is now known as MTN881001, and not DR-N 3DIM.
The Schneider Electric (MTN881001) files are located on The Exchange Download Center
  • Download the XIF / NXE files for the SE MN881001
  • Download the XIF / NXE files for the SVEA DR-N 3DIM
Note: It appears that although these devices are both classified as Lon I/O Module 1-10V, the XIF / NXE files are different.
Labels (5)
  • EcoStruxure Building Expert
  • Satchwell BAS & Sigma
SVEA 3DIM 1-10V.zip
MTN881001 Software.zip
  • 16311
