XBuilder Device Editor Modbus register formats
  • XBuilder Device Editor Modbus register formats
‎2018-09-06 02:22 PM
Last Updated: Crewman ContentModerator ‎2025-08-11 04:08 AM
When creating a Modbus device template in XBuilder Device Editor which Modbus register data type should be used?
Satchwell MicroNet, TAC INET, TAC Vista
  • Xenta Servers
  • Xenta 511, 527, 701, 711, 721, 731, 913
  • XBuilder
  • Modbus Register
  • Bitmask
Lack of consistency between Modbus slave manufacturers there is a large number of data formats that can be selected. Each register format interprets the value differently based on byte order or purpose of the specific bits.
  1. Consult Modbus slave product documentation
  2. Use trial and error to find the correct register format.
  3. Perform communication logging to capture the raw data and compare with a known value to determine the format.
As a tool to assist with these steps please consult the Definition of Modbus Registers.
Labels (3)
  • Satchwell MicroNet
  • TAC INET
  • 4404
0% helpful (0/1)
