Workstation crashes when executing a search for TGML with property set to "Bindings"
  • Workstation crashes when executing a search for TGML with property set to "Bindings"
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 12:32 PM
Workstation crashes when executing a search for “Graphic – TGML” with search property set to “Bindings”.
TAC Vista 5.1.7
The binding column (and any other column too,) in the search window has an limit of 259 characters. If text is longer then 259 workstation will crash.
This problem is fixed i TAC Vista version 5.1.8. If the text is longer then 259 it will be truncated down to 259 characters.
  • 7568
