WorkPlace Tech Lon communication configuration for use with EBO.
  • WorkPlace Tech Lon communication configuration for use with EBO.
  • RandyDavis
    RandyDavis
  • chris_clerc
    chris_clerc
  • Leo_Tantalo
    Leo_Tantalo
‎2018-09-10 10:26 AM
Last Updated: Guinan RandyDavis Guinan ‎2023-09-11 01:57 AM
When using an Echelon U10/U20 USB or other Lon network adaptor for communication with a laptop and standalone WorkPlace Tech, not WorkPlace Tech Editor, you must change the default configuration settings.  The default Lon Network Domain ID length (1 byte), Domain ID (18 decimal) and Subnet (254) in the AS-P conflicts with the defaults used by WorkPlace Tech.
TAC IA Series, EcoStruxure Building Operation
  • I/A Series WorkPlace Tech (Lon Network communication settings)
  • Building Operation Automation Server Premium
Lon Network configuration
  1. Look at the LonWorks Network "Advanced" tab in the AS-P to determine the addressing information.
  2. Open the WorkPlace Tech WorkStation Communication Settings and select LonWorks.  Open the Change Address window
  3. Select the "Manual Setup" radio Button
  4. Modify to match the AS-P Lon Works Network configuration.  If a different Domain ID or subnet has been assigned in the AS-P, it will need to be assigned the same in WorkPlace Tech
  5. You can now browse the LonNetwork from the laptop.  If the MNL devices are assigned applications from the AS-P, do not modify the programs from the WorkPlace Tech Tool
Labels (2)
  • TAC IA Series
Tags (2)
  • 19534
  • RandyDavis20
100% helpful (7/7)
