Windows User's Account for logging into I/NET
  • Windows User's Account for logging into I/NET
  • Roger_Bently
    Roger_Bently
‎2018-09-06 03:04 PM
I/NET Seven 2.11 and above
With the release of I/NET Seven 2.11, there is a new feature where the user can utilize the Windows User’s Account to log into I/NET.
  1. Select Edit Host Computer Passwords from I/NET's main menu to open the Host Password editor.
  2. Select Add to open the Host Passwords Assignments editor.
  3. In the Name field, use up to 30 characters to define the user's Windows account name. Use the following syntax for this field:
    machine_name\user_name
    or
    domain_name\user_name
  4. The entry in the Name field must exactly match the user's Windows account name. The following characters cannot be used within the name: " / []: | =, + *? < >.
  5. The Password and Confirmation fields become inactive and are not used for this type of account. Skip these fields.
  6. Continue filling in the other fields and assigning functions to the account. If necessary, refer to the Host Passwords Assignments editor for instructions.
  7. Once this is set up, select Log Off, then Log On again and check the box for Current Windows User and the current user will be logged on automatically.
  • TAC INET
  • 2073
