Windows Error 1067 When Starting SigmaSvr in Windows Services
  • Windows Error 1067 When Starting SigmaSvr in Windows Services
  • RandyDavis
    RandyDavis
  • CraigEl
    CraigEl
  • Gary
    Gary
  • DavidChild
    DavidChild
  • Benji
    Benji
‎2018-09-10 02:26 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-04 11:34 PM
When attempting to start SigmaSvr for the first time after installing Sigma 4.08, the following error appears:
Windows could not start the SigmaSvr service on Local Computer. Error 1067: The process terminated unexpectedly.
Satchwell Sigma
Satchwell Sigma Software (Sigma 4.08)
This issue typically occurs when the Sigma USB dongle is not plugged in during the initial startup of the Sigma Server. Without the dongle, the service fails to initialize properly, and a .dmp (dump) file is generated in the Sigma directory after each failed attempt.
  • Insert the Sigma USB Dongle
    Ensure the dongle is securely connected to the machine.
  • Allow Driver Installation
    Wait for Windows to detect and install the necessary drivers for the dongle.
  • Start the Sigma Server
    Launch the SigmaSvr service from Windows Services.
  • Clean Up Dump Files
    Navigate to the Sigma installation directory and delete any .dmp files created during previous failed attempts.
  • Satchwell BAS & Sigma
Tags (3)
  • 18355
  • CraigEllis25
  • GaryMontague20
