Windows 7: Using Shell command in workstation program results in Windows 7 looking for batch file in wrong directory.
  • Windows 7: Using Shell command in workstation program results in Windows 7 looking for batch file in wrong directory.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 01:26 PM
When running a batch file to run an application located at C:\ from a Workstation program, Windows 7 attempts to run the application in the following location.
c:\progra~1\mocros~1\office14>plink.exe
  • Windows 7
  • CyberStation
  • WebClient
  • Shell
  • Batch
Cannot successfully launch external application via a batch file using Plain English Shell command.
Begin the batch file by specifying the fill path location.
For example:
CD\
plink.exe
  • 5912
0% helpful (0/1)
