Windows 7 Error "Access to c:\program files...\userprofile\continuum.mnu was denied".
  • Windows 7 Error "Access to c:\program files...\userprofile\continuum.mnu was denied".
  • BillNeville
    BillNeville
‎2018-09-06 01:32 PM
Windows 7 Standalone v1.93. Logged into Windows as admin. Try to edit Continuum menu page to put in custom backgrounds and  new .mnu file. Get error when going to run mode: "Access to c:\program...\userprofile\continuum.mnu was denied".
CyberStation running on Windows 7
Windows 7 has a security feature called User Account Control Settings that is designed to prevent potentially harmful programs from making changes to your computer. The default setting is Level 3 of 4. This setting may prevent the .MNU from updating.
  1. Note: The windows logged on user must have administrator-level privileges to perform this change.
  2. Change the User Account Control Setting to Never Notify.
  3. Open Control Panel -> User Accounts.
  4. Click on Change User Account Control Settings.
  5. Drag the control to the lowest setting (Never Notify) and save.
  6. Restart Windows.
  • 5700
