Windows 7/10 User Account Control Settings
  • Windows 7/10 User Account Control Settings
  • RobertAndriolo
    RobertAndriolo
‎2018-09-06 01:40 PM
Last Updated: Picard RobertAndriolo Picard ‎2022-08-23 08:30 PM
The following issues have been found to occur due to the Windows 7 User Account Control Settings:
  • When starting I/NET, receive an error message indicating, "This is an unregistered version of I/NET.  Please contact TAC to register this copy of I/Net."
  • DBCreate does not accept Windows Authentication login.  It only allows access to DBCreate using the SQL Server authentication login option.
  • Login Issue with SevenReports (Crystal Reports)
TAC I/NET
  • I/NET Seven 2.4x
  • Windows 7
  • Windows 10
The User Account Control Settings appears to block access to these files required by the I/NET applications.
Set the User Account Control Settings to "Never notify".
  1. Go to Windows Start Icon
  2. In the Search prompt, type in User Account - Select the option "Change User Account Control settings" from the Control Panel options shown below:
  3. The default setting is shown.
  4. Change this setting to "Never notify."
  5. You will be presented with the following confirmation - Select Yes
  6. Restart your PC
  7. Test the issue and re-install I/NET (a repair may be adequate) if the issue remains before contacting support.
This setting is only required to be done once for all users on the PC.
  • TAC INET
Tags (3)
  • 5549
  • RobertAndriolo20
  • RobertAndriolo22
