Which signal types can be connected to a UI on a Xenta I/O Modules?
  • Which signal types can be connected to a UI on a Xenta I/O Modules?
  • CraigEl
    CraigEl
  • Zhenting_HU
    Zhenting_HU
‎2018-09-10 05:16 AM
Last Updated: Administrator CraigEl Administrator ‎2022-08-09 09:53 PM
TAC Vista
  • Xenta 451A/452A, 421A/422A
UI is short for universal input, which means that these inputs are compatible with many different input types.
Supported input signal types are:
  1. Thermistor: 1.8 KΩ at 25 °C or 10KΩ at 25 °C;
  2. Voltage: 0 to 10VDC;
  3. Current: 0 to 20mA;
  4. Digital Input.
Refer to the following link about 1.8KΩ and 10KΩ thermistor compatibility:
  1. 1.8k Thermistor compatibility with Xenta controllers
  2. 10k Thermistor compatibility with Xenta controllers
  • 6676
