When using an SQL Server CAL licensing model, which parts of the Security Expert system will require Microsoft SQL device CAL's?
  • When using an SQL Server CAL licensing model, which parts of the Security Expert system will require Microsoft SQL device CAL...
  • AdamSteele
    AdamSteele
‎2018-09-06 07:32 AM
Last Updated: Guinan AdamSteele Guinan ‎2023-11-23 06:18 PM
With Microsoft's new licensing model there is uncertainty around which parts of a Security Expert system need to allow for addition device CAL's for SQL Server.
EcoStruxure Security Expert
  • Security Expert
  • Microsoft SQL Server
Unclear documentation.
Security Expert Controllers do not talk to the SQL Server, are not a client on SQL and do not require a CAL. The Controllers talk to the Security Expert Software, not SQL or the Operating System.
  1. A card holding user who is NOT a Security Expert Operator will not require a CAL.
  2. The Controller and any attached equipment are NOT a user in SQL, they do not inject or operate queries against it, so a CAL is not required.
  3. A CAL would be required for a Windows user to log into their Windows user account, and the Security Expert client would connect to the Server using the CAL associated with the Windows user account.
  • EcoStruxure Security Expert
Tags (5)
  • 19658
  • AdamSteele20
  • AdamSteele21
  • AdamSteele23
  • AdamSteele25
100% helpful (1/1)
