When trying to access TAC Webstation a message saying 'Service unavailable' occurs.
  • When trying to access TAC Webstation a message saying 'Service unavailable' occurs.
  • Jonas_Brissman
    Jonas_Brissman
‎2018-09-06 02:39 PM
Webstation
The problem is that the application pool in the IIS where TAC Vista Webstation is located is closed down when trying to access it.
The workaround for this is:
  1. Go to Properties for the application pool which contains TAC Vista Webstation
  2. Choose Identity and change the predefined 'Network service' to 'local system'
  • 3362
