When should the Modbus RTU Annex points be used?
  • When should the Modbus RTU Annex points be used?
  • CraigEl
    CraigEl
  • PaulFr
    PaulFr
‎2018-09-06 12:04 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-10 02:05 AM
What is the best way to update Modbus RTU points through the X Driver?
Andover Continuum
Continuum Modbus RTU XDriver
Requesting values directly will cause additional polling to occur and may conflict with the Plain English polling program.
Polling of the X Driver points should be performed by a single Plain English program (or sequenced programs) that ensure only 2 requests are made per second (See Typical data throughput rates for Modbus XDrivers).
Whenever programs, graphics, alarms, list views etc are going to be used to read the X Driver values then annex points should be used.
An Annex point is a numeric point (not an X Driver point) that will get automatically updated by the X Driver if its name is put into Parameter 6 of the X Driver point.
Annex points are required for block reads, but even if you are doing an individual value read, this is the most efficient way of mapping the X Driver point value into another point that can be used by the rest of the system.
Another advantage of using annex points is that if an invalid or bad value is received by the X Driver, it does not update the Annex point even though sometimes the X Driver point itself can go to a NotSet or a 0 value until the next valid read is received. The annex point always holds the last known good value.
Also see Using Modbus RTU X Driver to connect to PM700 and PM750 Power meters for an example application for polling Schneider Electric power meters.
  • 11220
