When opening a Sigma Flexima CSV export text file in Microsoft Excel an error message occurs 'File not loaded completely'
  • When opening a Sigma Flexima CSV export text file in Microsoft Excel an error message occurs 'File not loaded completely'
  • CraigEl
    CraigEl
  • RogerHa
    RogerHa
‎2018-09-06 02:42 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-08 06:31 PM
When opening a Sigma Flexima CSV export text file in Microsoft Excel, the following error message appears:
“File not loaded completely”
Satchwell BAS & Sigma
  • Sigma Flexima
  • Microsoft Excel 2003
This issue occurs because the Flexima export file contains more data than the version of Excel being used can handle in a single worksheet. Older versions of Excel (2003 and earlier) are limited to 65,536 rows, which can easily be exceeded by Flexima exports. Newer versions (2007 and later) support over 1 million rows, resolving this limitation.
To resolve this issue, consider the following options:
✅ Option 1: Reduce Export File Size
  • Run more frequent Flexima extractions from the Sigma Scheduler.
  • This will generate smaller CSV files that stay within Excel’s row limits.
✅ Option 2: Upgrade Excel Version
  • Use Excel 2007 or later, which supports up to 1,048,576 rows.
  • This will allow the full file to load without errors.
Additional Notes
  • This issue is specific to older versions of Excel.
  • Always verify the row count and file size before opening large CSV exports.
  • Consider using Excel’s Power Query or Text Import Wizard for better handling of large datasets.
  • Satchwell BAS & Sigma
Tags (2)
  • 3267
  • CraigEllis25
