When making changes to the Personnel Manager to show custom attribute names, are these changes seen on all Workstations or just on the Workstation where the changes are made?
  • When making changes to the Personnel Manager to show custom attribute names, are these changes seen on all Workstations or ju...
  • AdamSteele
    AdamSteele
‎2018-09-11 03:40 AM
Continuum
Personnel Manager
Not sure if these changes will need to be made to all Workstations or if this is only required to be done once.
Any changes to the display name of the various attributes in the Personnel Manager using the Customize Attributes setting are applied to the database and will be seen by all other Cyberstations on that network. Basically, you will only need to make these changes once and not for each Workstation in your Continuum system.
  • 12848
