When logging in via WebStation the initial screen is blank
Select a Country
  • When logging in via WebStation the initial screen is blank
  • RobertAndriolo
    RobertAndriolo
  • Benji
    Benji
  • LeeCravens
    LeeCravens
  • AbeMeran
    AbeMeran
‎2018-09-11 07:37 AM
When logging in via WorkStation all is fine, but logging in via WebStation shows a blank initial screen (see below).
WebStation
The system has been configured with a user defined default workspace.
The default workspace contains an 'ampersand (&)' in the name.
Apply hot fix 1.6.1.28100 or remove the ampersand character from the workspace's name.
NOTE: This issue exists in all versions of StruxureWare Building Operation prior to 1.8, as of the writing of this article only 1.6.1 had a hot fix available to solve the problem.
The issue has been resolved in StruxureWare Building Operation version 1.8
  • 18318
0% helpful (0/1)
