What size is the fuse in an X96-BAT battery pack
  • What size is the fuse in an X96-BAT battery pack
  • CraigEl
    CraigEl
  • Gary
    Gary
‎2018-09-06 01:06 PM
Last Updated: Administrator CraigEl Administrator ‎2025-10-07 06:24 PM
Information is required to identify the correct fuse type for replacing the fuse in an X96-BAT battery pack.
Satchwell BAS & Sigma
UNC-X96
The fuse in the X96-BAT battery pack may need replacement due to wear, damage, or failure during operation.
The X96-BAT battery pack includes a fuse holder containing a 5 Amp quick-blow fuse.
When replacing the fuse, ensure the following specifications are met:
  • Type: Quick-blow (fast-acting) fuse
  • Rating: 5 Amps
  • Location: Inside the fuse holder of the X96-BAT battery pack
  • Satchwell BAS & Sigma
Tags (2)
  • 6527
  • CraigEllis25
