Niagara R2 LON and Serial Tunnel Client Port Configuration
  • Niagara R2 LON and Serial Tunnel Client Port Configuration
  • CraigEl
    CraigEl
  • Leo_Tantalo
    Leo_Tantalo
  • sesa116868
    sesa116868
‎2018-09-06 09:59 AM
Last Updated: Administrator CraigEl Administrator ‎2025-12-04 06:08 PM
What port is used for the Niagara R2 LON and Serial tunnel clients?
TAC IA Series
Niagara R2
Network configuration changes require port forwarding for tunneling. The correct port must be identified to allow communication through routers and firewalls.
The LON and Serial tunnel clients use the same port as the UNC station.
  • Default port: 80
  • If the station port is modified, the tunnel clients will use the updated port number.
  • TAC IA Series
Tags (2)
  • 14644
  • CraigEllis25
