What is the replacement sensor for a Satchwell DR2252?
  • What is the replacement sensor for a Satchwell DR2252?
  • sesa125819
    sesa125819
‎2018-09-10 11:58 PM
Replacing a Satchwell DR2252 sensor.
DR2252
Sensor
Detector
Replacement
The Satchwell DR2252 sensor is obsolete, and there is not a direct replacement.
The Satchwell DR2252 sensor is obsolete and the nearest replacement is the Schneider Electric STR614, but this is not a direct replacement.
The DR2252 sensor had a sensing element with a resistance of 1690 ohms at 20'C, and a concealed 10/35'C adjustable scale.
The Schneider Electric STR614 sensor has a sensing element with a resistance of 1690 ohms at 20'C, it does not have a concealed adjustment scale.
For the Schneider Electric STR600 series of sensors, please click HERE.
  • Field Devices
  • 8137
