What is the replacement gland kit for a Satchwell valve which has a 9.5mm diameter spindle?
  • What is the replacement gland kit for a Satchwell valve which has a 9.5mm diameter spindle?
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-11 08:01 AM
A replacement gland kit for a Satchwell 9.5mm valve spindle is required.
Satchwell
Gland Kit
9.5mm spindle
Customer cannot identify the valve, but has accurately measured the spindle.
A 9.5mm spindle was used on the VZF/MZF 65mm-150mm valve ranges, therefore the gland kit is the 626-9-311.
To review the VZF data sheet please click HERE.
To review the MZF data sheet please click HERE.
  • Field Devices
  • 14095
