What is the replacement actuator for a Satchwell AMH2451, when fitted on a VZF1954 valve?
  • What is the replacement actuator for a Satchwell AMH2451, when fitted on a VZF1954 valve?
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-11 06:07 AM
 AMH2451 replacement is required..
AMH2451
Satchwell
The AMH2451 is obsolete.
The replacement Schneider Electric actuator will be the MV15B-230 with a L7SV - the combined order code is 880-0660-000.
To review the data sheet for the MV15B, please click HERE.
To review the data sheet for the AMH2451, please click HERE.
To review the data sheet for the VZF1954, please click HERE.
  • Field Devices
  • 14291
