What is the purpose of the object called "Object Creator"?
  • What is the purpose of the object called "Object Creator"?
  • Jonas_Brissman
    Jonas_Brissman
  • Benji
    Benji
‎2018-09-10 04:01 AM
If creating a new "Utility" in Workstation it is possible to create a object called " Object Creator". This object is not documented.
WorkStation version 1.7.1 and earlier
There is no documentation for this object, as it is an internal test object that should not be used in the field.
visible and if you use it wrong it will crash. In 1.8 it is removedIt’sIt’sIt’s actually a internal test object used to quickly
create a folder structure. It shouldn’t be used as it isn’t supposed to be
visible and if you use it wrong it will crash. In 1.8 it is removedactually a internal test object used to quickly
visible and if you use it wrong it will crash. In 1.8 it is removedIt’s actually a internal test object used to quickly
The object is removed in version 1.8
  • 18558
