What is the maximum binding count per TGML graphic when polling OPC tags?
  • What is the maximum binding count per TGML graphic when polling OPC tags?
  • Jonas_Brissman
    Jonas_Brissman
  • sesa177673
    sesa177673
‎2018-09-06 12:56 PM
Last Updated: Janeway Jonas_Brissman Janeway ‎2023-08-17 04:17 AM
What is the maximum binding count per graphic when polling OPC tags?
TAC Vista
  • Vista Server
  • Vista OPC Server
There is no limit to the number of OPC tags, but performance may be affected when a large number of binding are used.
The load on the Vista server should be considered. E.g. datatypes and the update period:
  • Does an outside air temperature tag need to be updated every 10 seconds or is 10 minutes maybe more appropriate?
  • Can binary signals be combined into a single register?
Tags (2)
  • 6856
  • JonasBrissman23
