What is difference between valve rangeability and turndown ratio?
  • What is difference between valve rangeability and turndown ratio?
  • CraigEl
    CraigEl
  • sesa119747
    sesa119747
‎2018-09-06 02:30 PM
Last Updated: Administrator CraigEl Administrator ‎2022-08-30 11:12 PM
Field Devices
Valves
Definition of the terms helps explain the flow outcomes.
Rangeability - maximum controllable flow divided by minimum controllable flow
Turndown ratio - normal maximum system flow divided by minimum controllable flow.
Rangeability is the inherent characteristic of the valve and turndown ratio is the installed characteristic.
  • Field Devices
  • 3779
100% helpful (1/1)
