What gender are the DB-25 connectors on the DM-20, DIO-20 and DO-20?
  • What gender are the DB-25 connectors on the DM-20, DIO-20 and DO-20?
  • BillNeville
    BillNeville
‎2018-09-06 10:19 AM
Need to know the connector genders to order the interconnecting ribbon cable.
DO-20 DM-20 DIO-20
Not in the documentation for the DO-20.
All three have a female DB25 connector. Also, the interconnecting cable from the DM-20 to the DO-20 or DIO-20 is a straight-through 25 conductor cable.
  • 13552
