What Batteries and PSU Cards Can Be Used in a BAS or Sigma Controller?
  • What Batteries and PSU Cards Can Be Used in a BAS or Sigma Controller?
  • CraigEl
    CraigEl
‎2018-09-06 12:16 PM
Last Updated: Administrator CraigEl Administrator ‎2025-11-04 06:48 PM
Clarification is needed on which batteries and PSU cards are compatible with x96 controllers in the BAS & Sigma systems.
Satchwell BAS & Sigma
  • S-x96-STD
  • S-x96-BAT
  • Satchwell Sigma
  • Satchwell BAS
Due to changes in battery legislation and evolving hardware requirements, selecting the correct battery and PSU card for BAS & Sigma controllers can be confusing. Additionally, spare parts are no longer available for sale.
Battery Options for Sigma Controllers:
Part Number Description Battery Type Voltage Capacity Runtime
S-ARM7-BAT ARM7 CPU Board Battery Ni-MH 2-Button Cell 2.4V 80mAh —
S-V53-BAT V53/V25 CPU Board Battery Ni-MH 3-Button Cell 3.6V 150mAh —
S-X96-BAT Hi-Capacity Battery for x96 Ni-MH D-Cell Pack 10.8V 5Ah ~12 hours
S-X96-STD Standard Capacity Battery for x96 Ni-MH AA-Cell Pack 10.8V 1500mAh ~1.2 hours
⚠️ Note: Due to UK legislation (2006), NiCad batteries are no longer permitted. NiMH batteries are now standard.
Availability Notice
🚫 No spare parts are available for sale.
Customers should consider alternative solutions such as system upgrades or contacting Schneider Electric support for guidance.
PSU Card Compatibility Guidelines
Timeframe PSU Card Notes
11/2008 – Present PSU cards support both NiMH and NiCad batteries. No replacement needed.
04/2004 – 10/2008 PSU card must be replaced to fully charge NiMH batteries.
1999 – 03/2004 PSU card must be replaced to fully charge NiMH batteries.
Pre-1999 Requires 2 resistors (included with NiMH battery). See TPA for details.
  • Satchwell BAS & Sigma
Tags (9)
  • 196
  • 296
  • 496
  • 596
  • 696
  • 796
  • 8243
  • CraigEllis25
  • DavidChild21
100% helpful (1/1)
