What are the minimum user security settings required for a CyberStation user to reload a controller?
  • What are the minimum user security settings required for a CyberStation user to reload a controller?
  • BillNeville
    BillNeville
‎2018-09-06 01:40 PM
Some system administrators wish to set up very limited privileges for certain users but need those same users to be able to do a controller reload. What are the minimum user security "keys" required to set this up?
Continuum CyberStation
Incorrect user security settings (locks vs. keys) will not allow a logged on user to reload a controller.
In order for a limited user to be able to reload a controller, that user must have user security settings to reset, teach, create, and edit (if applicable) every item inside that particular controller (i.e., InfinityNumerics, Infinity Inputs, schedules, groups, etc.) as well as  the same privileges for controller object itself. See also the CyberStation Online Help System under Security Editor topic.
  • 5451
