What are the cable specifications for wiring controller inputs to field devices.
  • What are the cable specifications for wiring controller inputs to field devices.
  • JohnBoehmer
    JohnBoehmer
‎2018-09-06 09:39 AM
  • Inputs
  • Cable
  • Sensors
  • End devices
There is no specification for IO field wiring.
The line drop produced by cable resistance should be taken into account when choosing the wire gage for Input devices.
It is good practice to run a shielded cable for analog inputs simply because it give you a way to drain off any externally induced voltage.
  • 15823
