What amount of memory is used for DPU Resident Individuals in DPU/SCU controller
  • What amount of memory is used for DPU Resident Individuals in DPU/SCU controller
‎2020-10-13 03:31 PM
Last Updated: Crewman ContentModerator ‎2025-09-25 03:24 AM
What amount of memory is used for DPU Resident Individuals in the DPU\SCU controller?
TAC I/NET
  • I/NET Seven - Access control
  • DPU7910A, DPU7920, DPU7920 w/DPU48K, and SCU1284
Need to understand the memory allocation and implications of using DPU Resident settings with both the DPU or SCU hardware devices.
To set the Individual as DPU Resident the DPU Res. checkbox needs to be checked in the Individuals editor as shown below (red box) shown below.
In the table below from TCON300 05/17 Chapter 9-14 shows the memory allocation for a 7910A DPU or DPU7920
If you have a selection of between 6000 to 12000 Resident User Individuals (i.e. set as DPU Resident) in the system you can ONLY have between 3262 to 2887 Cached users respectively stored within a properly communicating system.  If the DPU is offline to the Sub LAN Interface (SLI) these cached users will be reduced as the requirement for the DPU storage capacity will need to store 'offline' messages as shown under the "Messages" column.
In the table below from TCON300 05/17 Chapter 9-15  shows the memory allocation for a SCU1284 DPU or DPU7920 w/DPU48K
If you have a selection of between 6000 to 12000 Resident Users Individuals (i.e. set as DPU Resident) in the system you can have the full quota of 48,000 Cache Users respectively stored within a properly communicating system.  Unlike the DPU7910 or 7920 if the DPU is offline to the Sub LAN Interface (SLI) there is no change to these cached users and there is more 'offline' message storage as shown under the "Messages" column.
For further information on DPU Caching and memory management read from Chapter 9-11 in TCON300-05/17
  • TAC INET
Tags (3)
  • 2891
  • RobertAndriolo19
  • RobertAndriolo20
