What Schneider Electric actuator can be used to replace a 230 volt Satchwell mains actuator fitted onto a MZxxx valve?
  • What Schneider Electric actuator can be used to replace a 230 volt Satchwell mains actuator fitted onto a MZxxx valve?
  • sesa139513
    sesa139513
  • sesa125819
    sesa125819
‎2018-09-11 01:29 AM
Replacing a 230 volt Satchwell mains actuator.
Satchwell
MZxxx
Valve
Mains
Actuator
Old Satchwell actuator is obsolete.
The replacement mains actuator will be the MV15B-230 spec - 880-0460-000 for datasheet please click HERE.
To fit the MV15B-230 actuator to a Satchwell MZxxx valve a L7SV linkage is required. spec 880-0126-000
  • Field Devices
  • 12694
