What LDAP sources can the Personnel Import Utility interface to?
  • What LDAP sources can the Personnel Import Utility interface to?
  • AdamSteele
    AdamSteele
‎2018-09-06 10:29 AM
Do we support LDAP sources other than Microsoft Active Directory? Such as interfacing to Oracle Databases, OpenLDAP, Apple LDAP, etc…
Continuum
Customer wants to use an LDAP source other than  Microsoft Active Directory.
The only LDAP scenario that has been tested for was interfacing with Microsoft Active Directory, no other LDAP source has been tested or qualified at this time.
Other LDAP sources may work but as these have not been qualified we have no way of knowing for sure.
Tags (2)
  • 13021
  • piu
