Webpinpoint will not run Plain English script that works in Cyberstation Pinpoint
  • Webpinpoint will not run Plain English script that works in Cyberstation Pinpoint
  • Alan_Wood
    Alan_Wood
‎2018-09-06 12:39 PM
Nothing happens or an error ' You have insufficient rights to perform this operation' happens when clicking a webpinpoint graphic that is set up with a Plain English script.
Webclient
Web Pinpoint
Windows XP
Windows Vista
Windows 7
Windows Server 2003
Windows Server 2008
Webpinpoint does not support running PE programs like Cyberstation Pinpoint does.
Webpinpoint does not support running PE programs like Cyberstation does.
A possible work around to this would be to set up a numeric that gets changed when a button is pushed.
A program can be set up as looping to be triggered by this numeric and the code executed to perform the operation needed.
  • 7356
