Webpinpoint gives error, Could not connect to server. Cause:Type missing for member of type Object_ContectID
  • Webpinpoint gives error, Could not connect to server. Cause:Type missing for member of type Object_ContectID
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:47 PM
Webpinpoint graphics for webclient
.NET Framework 1.1
Hotfix issued by Microsoft (KB928366) was installed.
This issue happens on webpinpoint graphics for webclient installations using .NET Framework 1.1, versions 1.6x through 1.73.
A hotfix was issued by Microsoft that caused this issue KB928366.
The solution is to remove KB928366 or upgrade to a version of webclient that uses .NET Framework 2.0, versions 1.74 or greater.
  • 3053
