Webclient Pinpoint installation generates the error, Object doesn't support this property or method error or Webpinpoint keeps trying to install
  • Webclient Pinpoint installation generates the error, Object doesn't support this property or method error or Webpinpoint keep...
  • Alan_Wood
    Alan_Wood
‎2018-09-06 02:19 PM
The Webclient Pinpoint installation generates an error 'Object doesn't support this property or method'  when attempting to access a graphic for the first time from Internet Explorer. Webpinpoint may also try to keep installing.
Windows XP
Windows 2003
Continuum 1.9x
Occasionally permission issues on a PC may cause the webclientpinpointsetup.cab not to copy to it's installation folder.
  1. Search the webclient PC hard drive for the file webclientpinpointsetup.cab (On the CD or Zip file - Continuum>Misc folder)
  2. Copy it to c:\program files\webserver\redist folder.
  3. Launch a graphic and then pinpoint will install properly
  • 4257
