WebReports installer crashes when attempting connection to the Enterprise Server
  • WebReports installer crashes when attempting connection to the Enterprise Server
  • RobertAndriolo
    RobertAndriolo
  • Benji
    Benji
‎2018-09-10 01:45 PM
Last Updated: Picard RobertAndriolo Picard ‎2021-08-17 12:26 AM
During the installation of WebReports, the installer crashes when clicking "Continue" in the "Reporting Agent" step.
"StruxureWare Building Operation has stopped working"
WebReports
There is an issue with the installer when FIPS (Federal Information Processing Standards) algorithms are enforced.
  1. Open the local group policy editor (Start > run > gpedit.msc)
  2. Navigate to "Local Computer Policy > Computer Configuration > Windows Settings > Security Settings > Local Policies > Security Options"
  3. Locate the following item in the list on the right: "System cryptography: Use FIPS compliant algorithms for encryption, hashing, and signing"
  4. Edit the item, and select "Disabled"
  5. Install WebReports
    Example of FIPS being enabled
Tags (2)
  • 18569
  • RobertAndriolo21
