WebReports/Report Server discontinuation in EBO 2022 or higher (Migration to External Log Storage)
  • WebReports/Report Server discontinuation in EBO 2022 or higher (Migration to External Log Storage)
  • Mahmoud_Sayed
    Mahmoud_Sayed
Kirk Mahmoud_Sayed Kirk
‎2022-06-22 01:54 AM
Last Updated: Administrator CraigEl Administrator ‎2025-08-15 06:38 PM
Sites using Report Server need to upgrade to EcoStruxure Building Operation (EBO) 2022 or higher, where WebReports/Report Server is no longer supported.
  • Building Operation Enterprise Central
  • Building Operation Report Server
  • Building Operation Timescale Database
WebReports/Report Server is not supported in EBO 2022 (version 4.0) or higher.
To address this, Schneider Electric provides a Data Migration Assistant (DMA) tool that:
  • Reads data from WebReports 3.x
  • Writes data to External Log Storage
  • Download the DMA Tool
External Log Storage Overview
  • Stores historical data from EcoStruxure BMS
  • Storage capacity is limited only by your hardware
  • Historical data is displayed in WorkStation and WebStation (event and trend views)
  • Any server can be configured to write data to TimescaleDB
Any server in the system can be configured to write historical data to the TimescaleDB database.Any server in the system can be configured to write historical data to the TimescaleDB database.
Licensing Requirements
  • External Log Storage requires a license
  • Refer to:
    • Software and Features that Require Licenses
    • Part Number Summary and Hardware Software Matrix
Hardware & Software Requirements
Ensure compatibility with:
  • TimescaleDB
  • PostgreSQL
Recommended specs for large systems (e.g., 100 BMS servers):
  • High-performance SSD
  • Minimum 64 GB RAM
  • Additional CPU capacity
Refer to:
  • IT System Planning Guide
Merging Log Data
  • External Log Storage reduces extended trend logs on BMS servers
  • You can merge extended trend logs into source logs in External Log Storage
  • See: Merging of Trend Log Data
Enhanced Reporting (XLSX Templates)
EBO servers (v3.2 or higher) support native reporting with:
  • Text and XLSX formats
  • Advanced XLSX features: formulas, conditional formatting, charts, sparklines
  • Historical data pulled from External Log Storage (PostgreSQL/TimescaleDB)
Refer to:
  • Examples for Native EBO Notification Reports
Tags (2)
  • MahmoudSayed22
  • MahmoudSayed25
50% helpful (1/2)
